The latest Yamaha ATV & UTV articles featuring Tech & Reviews for YFZ 450R, Grizzly 550, Raptor 700R, Rhino, Big Bear, Wolverine - ATV at Off-Road.com
ATV & UTV »
Price and Compare Vehicles:
New, Used, and Powersports    Go button
Tech: Yamaha
New model reviews from ATV pro riders and experts featuring Yamaha Sport & Utility ATVs and UTVs like YFZ 450R, Grizzly 550, Raptor 700R, Rhino, Big Bear, Wolverine, Raptor 90 and Banshee. The latest Yamaha ATV articles featuring tech for engines, suspension, wheels, tires, carburetors, EFI, air filter, intake, exhaust pipes, off-road lights, suspension seats, gauges, shocks, GPS, safety devices and off-road trips.
ATV AnswerMan: October Questions and Answers
October 22, 2009
I have a problem with my 2001 Yamaha Wolverine 350. I have lost a substantial amount of torque. It only acts like that when going up a hill, when its pulling a load, or going through a mudhole.. Is the clutch slipping or what?
First Ride: 2010 Yamaha YFZ450X
September 20, 2009
The frame on the new YFZ450X is exactly the same as the YFZ450R, though front suspension low side pivot points are moved inward and are 16mm closer together than the original YFZ450. The upper pivot placement has also been moved 59mm closer together.
Blog: YFZ450R Tuning Upgrade with DynoJet
September 19, 2009
This is a very simple upgrade, slightly expensive, but a very important modification for any Fuel-Injected quad. When you start making changes like adding an exhaust, modifying the air box for a new filter, and especially changing up the motor on this ATV, you have to change the air/fuel ratio.
Yamaha Announces 2010 ATV Line-Up Including New YFZ450X
September 8, 2009
In total Yamaha will produce 17 ATV models for 2010 including class-leading, best-selling models from its Grizzly utility line and Raptor and YFZ sport lines.
Fluidyne Powersports Radiator Gives Yamaha's YFZ450R 40% More Coolant Capacity
August 17, 2009
FLUIDYNE's® new YFZ-R radiator is stronger and more durable than its OEM counterpart. Constructed from aircraft-quality aluminum, structural improvements include thicker materials throughout, a CNC-machined billet filler neck, beaded hose connections for leak-proof sealing and a stainless-steel radiator cap rated at 16 lbs.
Rally Around the Rhino
July 10, 2009
Yamaha is recommending their owners go out and get some basic safety modifications to the Rhino UTVs. At no cost to the owner. Small changes can be made, but it comes down to Safe, Responsible use
Rhino Safety Video Montage
July 3, 2009
Capture some of the rocks, dirt and heat from the hills of San Bernadino.
Yamaha YFZ450R Full Chassis Armor & Swing Arm Armor
May 20, 2009
The unique design allows for extra protection for your fuel and oil lines. Access holes allow you to easily maintain your ATV without having to remove the frame armor.
Raptor 250 Complete Armor and Front Bumper
May 19, 2009
They have designed a great full chassis armor and swing arm armor to keep you protected no matter what you throw at it.
Untitled Document
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
Enewsletters
Stay on Top of All the Action:
Sign up for Off-Road.com's Enewsletters
Click here
